EV Charger for Sunsynk Max
I own a Sunsynk Max Single phase and am happy with it. Getting a new EV car and looking for a Smart EV to integrate into my Max. Also intending to use the Auxiliary output that as I am advised can carry a 50% load of the Inverter rating. As I have a 16kw inverter, a 7.3kw inverter should be able to be supported.
Any recommendations of brand and also my usage of the Aux output?
While the SS inverter does allow you to do some kool stuff using the Aux port to divert excess power to your smart loads, have you consider using a Zappi EV charger. This will give you much more control and flexibility to manage charging your EV.
