Public·395 members
Philips Hue rules
I have set up a Philips Hue bridge with a Hue smart plug to control my immersion heater. I have set the plug to switch on at SOC > 75% but it does not switch off when SOC drops below 75% and I cannot add another rule to switch off when SOC is less than say 50% because there is no "<" symbol available in the rules. Also if I try to add a new rule when I select my Plant I get the message "The current power station is occupied".
jim.cockram
Jul 25, 2024
This is all very limiting. For Rules there is only SOC that can be used for creating a rule and some of the actions are limiting.
Does Sunsynk have any ambition to increase the capability of the Rules that can be created, including Kw being generated, Energy being exported/imported, Alarms/Faults being raised or Normal.
These would all be helpful to be able to then operate bulbs/colours, devices etc.
We should all understand that operating socket etc, needs to be within the capability of the Philip Hue device, and not switch devices such as immersion heaters etc.
