Does anyone have advice on maintaining a clean workspace when performing maintenance on solar inverter components or bat
Does anyone have advice on maintaining a clean workspace when performing maintenance on solar inverter components or batteries? I’m looking for a way to protect surfaces from grease or heat while keeping everything organized during technical repairs.
Keeping the workbench clean during inverter maintenance is a struggle, especially with thermal paste or grease. I’ve actually started using https://www.mcdonaldpaper.com/safepro-710r-x-9x10-75-inch-pre-cut-aluminum-foil-sheets-200-cs for this. They are pre-cut 9x10.75 inch sheets, so you don't have to fumble with a roll while your hands are busy. They’re super durable and heat-resistant, which is perfect for laying out small parts or protecting surfaces from drips. Getting them in a 200-count case makes it a cheap and easy way to keep the workspace professional and mess-free.
