Public·395 members
ECCO Inverters 5kw
Hi I have two 5kw Ecco inverters and will be linking them together... I am busy setting them out
in what is a fairly tight space. When opening the packaging I was shocked at how compact the inverter is.
I downloaded the instructions....and it shows on the diagram that these inverters need 500mm clear around them....so
does that mean I can position them 500mm apart. Looking at the you tube videos Keith states the inverters need a 1000mm
spacing.....but he appears to be talking about the standard inverters with side mounted fans. The Ecco invertes seem different...can anyone hear advise in an official capacity....is 500mm spacing ok.
Richard in sunny Bolton uk
richard
Feb 06, 2023
Thanks Keith ..... very much appreciated...
