Public·399 members
Long Distance from panel to inverter
I plan installing 24 JA 455w panels, VOC 53.85. VMP 45.60 IMP 9.98
connected to 2 - Sunsynk 5kW hybrid Inverter in parallel.
6 panels conected to a String Per MPPT Tracker, giving a current of 9.98 amp at a voltage of 273.60.
These will be pole mounted consisting of 4 panels on each unit, so six of them, and will have sun trackers.
The panels are a long way from where Inverter/batteries will be installed about 120 metres.
Calculating the volt drop will be about 8 volts on full load using 6 mm cables for each PV input.
I assume that voltage 273.6 on the MPPT Tracker is ok?
The 6 mm cables at a distance of 120 m is ok?
Thanks David
