Charging priority changed
Hi. I have a setup that was set to priority home->battery->export with the battery set to draw from the grid if needed to keep soc at 20%. I'm on a constant rate import tariff and a constant rate export tariff. In trying to add the different rates I tried setting the revenue info to live price as that seemed to let me put in the different rates but it also altered the settings of the inverter such that it now charges the battery to 100% from the grid. I found the setting in the equipment tab and noticed it was set to use timer (I never looked here before so I don't know if it was altered) and turned this off but it is still charging the battery to 100%. I want to set it back to how it originally was but settings I've changed don't seem to help
The app is also now showing house load at 0W for some reason
Here is my current system mode settings
And the battery settings
Our costs have doubled now with this so any assistance would be very appreciated
Quick edit work mode was set to zero export + Limit to load only, changed it to Limited to home and it is showing the home load now
Shutdown 20, Restart 50 and low batt 20. Note after turning use timer back on, the system is now behaving as it used to, though I'd appreciate any advice if these settings seem wrong (I never touched these, these were, I guess, set by the installer)
