Public·395 members
2 inverters 2 Bms 2 phases communication
Hello, I have currently installed 2 Sunsynk 6k 1ph inverters
Inverter_1 connected to phase A
Inverter_1 connected to phase B+C(i dont have 3ph loads, so thats okay for me now)
have battery bank with busbar connected with 2 BMS(there is no way i can connect 2 BMS to the inverter_1)
BMS_1 goes to Inverter_1
BMS_2 goes to Inverter_2
Inverter_1 is charging the battery bank using night grid and PV
If BMS_1 reports error, inverter_1 accepts error and stop. (but inverter_2 is still working)
If BMS_2 reports error inverter_2 accepts error and stop. (but inverter_1 is still working)
So the question is, if i make
Inverter_1 Master at phase A
Inverter_2 Master at phase B
connect them using cable, will they communicate about the error codes BMS send to them and resend to other inverter to stop?
