Public·330 members
Wi-fi change
Hi there, we have changed our WiFi, how and where can I change it in the App?
day help will be much appreciated, thanks in advance. CD
May 31, 2024
The manual can be found here - https://sunsynk.freshdesk.com/helpdesk/attachments/103025057097
I am not sure if you are aware, but when you changed your Wifi router, if you change the SSID and password of the new router to the same as it was on you old router then you do not have to change the DataLogger or any other devices that were using you old router
If you do want to change the Datalogger to use the new SSID and password, you will be able to browse to the default IP address  10.10.10.1 of the datalogger after connect to the wireless access point starting with 'EAP-'. The scan for the new network, put in the new password - just follow the details in the manual.
I cannot remember if you have to delete/remove the old connection before you can select the new connection for you new router.
