Public·332 members
Dominic Renshaw
Dominic Renshaw
Only 10% of power showing on the system screen.
We have two strings both produce around 3000kw so 6000kw in total, (we are reading the voltage and amps coming into each mttp which works out to be 3000kw for each string). However on the system flow chart is only show 600w which is 10% of the total? This must be a system setting but I'm struggling to find it, any help greatly appreciated.
Unknown member
Jul 28, 2024
So it will only take from the panels what it needs? so if the system is producing 6kwh, and we only need 2.7kw then the inverter will generally only show 2.7kw going in even though the voltage and amp going in to the mttp. (The reading from the testing meter are (292v, 12.8amps sting 1, and 262v, 12.82amps string 2).?
