Can a Sunsynk unit support loads higher than the inverter rating?
I am new to Sunsynk gear but hope to build on the success of the first unit going in.
Something that I can't seem to find out, but hopefully someone here can answer.
If I have an grid connected ECCO 3.6kw unit and the house 'load' requirement goes up to say 6Kw, does the ECCO blend 3.6kw from a combination of solar PV (in daylight) with power from the battery, with the shortfall supported by the grid? Thanks
Your inverter will be able to draw power from the grid, PV and battery up to the limit specified by the pass-through rating. You can find that on the specification sheet.
