Public·529 members
Does anyone know the pinout for Pylontech battery communications cable?
Hi all, does anyone know what the correct pinout should be for connecting Pylontech US300c batteries to Sunsynk inverter? Cheers.
peter.knapp
Aug 02, 2022
C models (i.e. US2000C/3000C/5000) are as follows: Pin4 CAN-H Pin5 CAN-L Pin6 CAN-Ground (Can be left disconnected) Pin7 - RS485A Pin8 - RS485B Pins 1-3 MUST be disconnected. A straight through patch lead will work fine, assuming you cut out pins 1-3. However that does mean it's not a twisted pair, as 4 and 5 are borrowing cores from different pairs, so I usually just crimp it up and use one pair for 4/5 and leave the rest disconnected (Same at both ends with Sunsynk fwiw)
