Public·395 members
F13 grid mode changed continuous error
Hi - getting this error from the inverter - a string of the same error every 5 minutes followed by the battery shutting down. Time of use minimum is 35% and grid is present. Seems it is using the batteries until their dead instead of switching to grid. Then batteries shut down and inverter goes into alarm mode and shuts down load. Anyone experience this? Will try reset a bit later.
Mike Ranch
20 lug 2021
Cheers @Vassen Moodley . Have now done a reset but the grid was connected. I.e. I didn't let the inverter shut off. But reset all settings using the inverter option. Will do it again if its still problematic after this. I read on another forum that the F13 took a couple tries to get rid of. Upgrade probably the answer but will wait for data logger.
