Public·399 members
Battery charge settings
Having spoken to sunsynk they confirmed that I can increase the battery charge ampage from 40a to 60a.
I went on the app under battery settings and changed to 50a in the first instance. However, it didn't make any difference.
I've gone to the main panel and there is a separate "battery type" which is now showing at 50a but the "battery charge" is still at 40a. Screenshots attached.
Does anyone know what the differences are/actually do?
AVONSIDE
Apr 02, 2023
as moto said
The way I see it - the first tab says BATT TYPE which is basically battery specification. I would set charge / discharge to 0.5C max [or limit of your cables / breaker]
the second tab is BATT CHARGE (from GRID) set that to the max value that you want to charge
As an aside, I assume you have a 5kw inverter, if so keep an eye on max power as at 85A you might be less than 5kW? If you want to extract the max that is.......
