Public·371 members
Sunsynk 5.32kw battery
Hi, please can someone advise. I have a sunsynk 5.32 battery and I am thinking of adding another battery.
What amp fuse will be sufficient?
I currently have a 160a.
Also can I use different brand batteries?
jacekowski
2024년 6월 04일
You need to get a compatible battery, sunsynk batteries are not even compatible between different models so you need to get same model as well (sunsynk doesn't actually make batteries, they have various OEMs build batteries for them).
160A fuse will be sufficient, as long as it is above your inverter current you going to be ok.
