Why does my batteries charge to 58.7v but ive set 60v
Hello,
I have a 6K invertor with a DIY Lithium battery with BMS, it has 16s with a lot not charged zone which i can live with. 66V working (i can only use on 60v)
So i set the inverter to Float-60v Absorb-60v Equal-60v (using Battery V charging setting which is AGM like,) . It got charging until 58.6v, then the power for charging dropped and dropped, and now im facing 58.7 with 100W of charge. Why is it so? Ive asked for 60V, where are my 60v, can you help me out?
Denis Dubinin
Denis Dubinin
Apr 12, 2023
exactly, i have a Li Ion batteries with a DIY Daly BMS, thats where i get that 4.2 max voltage and why i want to charge it max 60volts
Ive tried to set battery type to lithium, and cycled all 18 lithium modes, i guess it wont work if bms has not connection to inverter
so the thing is. Why im having 60volt set in settings and 58.8 charged max.
