Public·405 members
Sunsynk System 10kw
Hi I will shortly be installing 2xSunsynk 5kw inverters and a 10kw solar array..... 24 panels, I was going to divide the panels into 4 x 6 - so each MPPT would be fed (each Sunsynk 5kw inverter has 2 x mppt) would be fed by 6 panels in series (panels are JA Solar 405w VMPP: 31.21 V - IMPP: 12.98 A - Isc: 13.87 A - Voc: 37.23 V) 6 x 37.23 = 224 volts. I want to use a battery - I have an EEL 48v 15kw battery which users the Pylontec communication protocal. So it should communicate..... when connecting the battery I assume I need same length cables to each inverter........do I use big fuses (if so what value) or can I rely on suitable MCB's??? How do the inverters know how to share the load on the battery...... Also your observations would most welcome.
