Public·486 members
Sunsynk 8Kw setting Battery Start Discharge
Have Battery set to "Stop discharge set to 10%" and "Battery Start Discharge set to 50%".
When the battery gets to 10% Discharge it stiops and transfers to the Grid, when the PV starts generating a bit it starts charging the battery and when it gets to 11% it turns Grid off and takes current from Battery.
As the PV increases this change between Grid and Battery goes on quite quickly.
I assume this is switching relays in the inverter and cannot do it any good.
Why does the inverter not wait until the 50% setting is reached before starting to recharge battery?
How to sort this out.
David
Nicholas Strachan
Nicholas Strachan
Apr 08, 2023
Lots of things missing from your settings
