Public·332 members
Pylontech bms and charge voltage
the battery is hooked up via CAN bus, so the bms sets the charge voltage. My question is that it goes upto 53.5 volts and sometimes even 53.62 volts, when fully charged, is this a safe voltage for the Pylontech's
tebrahim2000
2021年2月04日
Hi @jp.vanriel,
thanks for your detailed explanation, helps a lot. I also asked Coulomb ( posts on the Powerforum ), as per him that as long as the voltage does not spike over 54 volts, not to worry about it.
yes, am aware of Victron setting it to 52.6 volts, but then it is two to three times more expensive, so maybe there lies the answer
