Public·388 members
Tricklefeed help
Good Afternoon,
Could someone explain what the Tricklefeed is used for? I see my tricklefeed in the mornings and evenings running at roughly 20W and during the day up to 60W. Why does the Sunsynk Inverter require a tricklefeed, to see if there is a mains electricity failure?
Many thanks
Warren
bob.kenair
May 16, 2023
HI warren,
The trickle feed is in the "Systems Mode" page2 if I remember (small cog top right on screen to get to the settings). One of the boxes in there has the Trickle amount, set yours to zero. You can also set the max amount you want to export on the same page. The other tick boxes let you decide what you want to do with the solar you are making. Remember to press OK or it wont save. Have a look at you overall flow dig before and after you make the changes to see if its doing what you want.
