Public·395 members
Trickle Feed Export to Grid
I recently had a new solar install with Sunsynk 8KW inverter with 20.48KWh Sunsynk battery bank. What I have noticed is that with the CT Coil and configuration I have set with Grid Trickle Feed set to zero, I am still finding that the grid import is at around 32W on average. I have SEG agreement in place and would prefer to have a small trickle export of 20W at all times than import trickle power from the grid which is costing me more because of day time tariff on Octopus Go. You can see below my current setup which supports in order of priority Solar -> House non-essential load -> Surplus solar export to grid. However I would like to change the trickle feed as an export to the grid than import. Can this be achieved with Sunsynk inverter and if yes how?
dadothebold
07 jul 2023
If you haven't come across this thread yet you need to take a look answeres grid draw
Not a fix buts stops us guessing
https://www.sunsynk.org/forum/technical-support/system-draws-36w-from-grid-while-solar-power-is-producing-during-the-day-but-0w-from-grid-when-drawing-from-battery
