A couple of technical questions
Can you clear up some technical questions please :
1) Without storage, where does the inverter self consumption come from ?
2) Does the inverter shut down at night if there is no solar ?
3) I see that the inverter has to be connected to Grid when used without batteries. (Training section 3.3.AC Grid Connection)
Does it draw power from the Grid ?
And Where must the Load be connected ?
4) What is the invertr's self consumption? I do not see that in the data sheets.
On another forum, I see the same question and someone mentions 200W !
In that case its 4.8kWh / day just to break even.
5) Later if I connect storage.
Does the inverter use battery voltage or SoC for control ?
Thank you in advance!
