Equipment Section, System mode.
What is the difference between the settings for Grid Charge and Gen Charge. There are times 1 - 6 for both?
Whether you want to charge from the Grid or a Generator to the SOC specified at a specifed time interval. Generally this would be an either or and not bot for the same period.
For this to be effective you also have to tick the Grid charge or Gen Charge option on the Battery Setup/Batt Charge screen on the console to specify the current values to use when charging.
