AC Breaker Value and Passthrough Technical meaning
Good morning,
AC Breaker for 5Kw system:
According to the Sunsynk User Manual for ECCO Hybrid Inverter (v.7(12/09/22) the recommended AC breaker for backup load should be 32A/40A and the AC breaker for grid 40A.
For the SUN- 5K model what is required to keep the warranty valid? I was informed by the supplier/distributor for Sunsynk that if the AC breaker is more than 25A for both the grid and backup load the warranty is void?
Related to this there seems to be a misunderstanding of the MAX Continuous AC Passthrough as this will obvious impact the breaker size. Please explain in detail what this means en when will/can this happen? Information I received from the supplier/distributor and other users are not the same. There were similar posts but I am still not sure how this exactly works.
Thank you in advance.
