Public·326 members
5KW battery on a 3.6 Hybrid
Hi, recently installed the above and since the beginning of November the battery has not discharged just showing charge. I have checked the settings over and over and all ok. Anyone any ideas
scott
25 nov. 2022
Are you still having an issue? Check your CT coil is correct and it measures a positive current from the grid when powering the house or charging the battery. Make sure you set the timer page up so that you request a low SOC when you want the batteries to discharge (for example 10%).
