Sunsynk 5kw to SSLB1 5.12kw battery communication
Have a Sunsynk 5kw inverter and the Sunsynk SSLB1 5.12KW battery. When I purchased the battery from Ellies there were no battery cables and comms cable. Phoned Sunsynk support and was advised I could use the Pylontech battery cables and Comms cable. Setup everything but cannot get the comms to the battery to work. The Li BMS does not show the correct battery data as depicted in the manual.
Should I use another comms cable(CANBUS). If so where may I purchase one?
I had to make up a lead for mine to my SS 3.6Kw Hybrid Inv and SSLB1 5.12KW CATL battery... This was the PINOUTS that worked for me and SS and I eventually found and advised..
