Correct system mode settings for total off-grid installation without any grid power connected
I have a Sunsynck8kva inverter with 16 460w panels and 2 Freedom One e-tower lithium batteries connected. I made provision for a generator connected in case i run out of battery power during the evenings and rainy season. I am still trying to understand the System Mode settings on my Sunsynck 8Kva inverter. What must the correct settings be under System Mode 2? No grid power will ever be connected.
I understand that the "Export power limiter" is to limit the power exported to the Grid. In some posts and also the manual, this setting is labelled "Inverter Power Limiter" which I think means "the maximum power the inverter can provide to any load". From the confusing manual.
For setting 2 it says on a different page in the manual "Solar Export" - "the ability to limit power supply to only the household loads".
I must say my inverter is running absolutely fine with the settings in the first pic, but it would be nice if I know exactly what each tick setting means.
What must the exact settings be for a total off grid setup.
That page is not doing anything in off grid setups
