System not producing as it should?
I have a 6.4kW array on my roof, 4.94 perfect south facing on a nicely angled roof, no shade.
A further 1.52 on a East facing roof, getting good sun still now as I type
The inverter is the 3.6 hybrid, which by all accounts is good for 7000W of solar.
At this moment in time, with perfect conditions, full sunshine on the whole array, cold temperatures, im only pulling 3697kw.
57% efficiency. It seems to limit itself to 3800w max.
This appears far too low. Anyone any ideas?
3.6 and 5kW inverters are actually the same hardware as far as i know, just that the 3.6 version is limited to lower power.
However, if you check the datasheet, it can deliver 4680W when charging batteries, or 3960W on AC output.
