Public·385 members
Exporting when batteries not full.
Hi All
Surely the sunsynk should only export to grid when the batteries are full ?
Tried limit to load doesn't make a difference to export (only essentials)
Battery CANBUS still full 600 amp max charge rate on.
If I turn off export I'd get 10kw at least into batterirs. Therefore no battery or bms issue.
Surely the sunsynk should export when battery is 100 percent of if the charge rate decreases then excess only should export.
Jean
Sep 28, 2022
Dear David , Limit to load will limit PV power to follow essential loads and all non essential loads will not be powered. to export power when batteries is 100% SOC you need to select zero export and then export as well.
