Agile Plugin
I have witnessed an issue whereby charging won't ever occur between 23h00 and 00h00 when set automatically by the octopus plugin.
In the schedule if it is cheap enough to charge between the hours of 23h30 and 00h0 it won't charge because of how the scheduler is set up. The automated schedule should instead be set to 23h30 and 24h00. When changing manually to ise 24h00 on the scheduler it reverts to 00h00 and stops charging.
This is for a 8k inverter. I can't get serial number just now as sunsynk is down again but will post this information back later. Are there any recent firmware updates that fix this issue?
You could raise a ticket at sunsynk.org. It’s been an issue for a long time and once you set timer three it’s done. A bit like the revenue payback issues that are worse than they were before they found a ‘fix’ and have been ongoing for several months.
If you want to force discharge this evening 6-6.30 with Octopus, you will get £1.75 per kWh - just opt in to the savings session on your octopus account.
