Earth neutral bond contactor not working
It seems like my earth neutral bond contactor is not being operated by the inverter.
I have enabled "signal island mode", but when in island mode i get nothing out of the ATS pins (can someone confirm that drawing below is correct for 5.5kW ecco (it's in the manual, but i don't trust it)). Any ideas or do i just have a faulty inverter?
Hi Jacekowski
Not really a help - but I have an 8kw ecco and I set it up like the manual and works fine. Needs to use a NC connector from memory. I can have a look at it all again and post here if you're still stuck?
