Public·330 members
8.8kw unit grid consumption data
Just installed the unit with pv array. As the 14kw lithium battery array is still 2 weeks away, using the unit to benefit from pv production during the day. Issue is that on the main display the grid wheel only shows consumption while pv is producing. Once the pv led goes off late afternoon, the grid dial shows zero. Under battery it shows the amp value correctly. Also on the flowchart the arrows do not run from grid to house when their is no pv
Achmat Kazie
Achmat Kazie
Jul 29, 2020
Try changing the setting to "Limit to load" and not "Limit to home"
