Public·391 members
SunSynk 5.12KW battery in IP65 housing - cell type?
Greetings!
I recently bought a 5.12KW battery that came in the IP65 housing (this one: https://www.sunsynk.org/ip65-battery)
but would like to add a second battery, and assume that I must add exactly the same battery to run two in parallel.
Question: Does this battery contain CATL or BYD cells? SS website or spec sheet has no info.
Are there any other options to add a SunSynk battery, or must it definitely be the one in the outdoor IP65 housing? Or can it be another SunSynk 5.12KW battery that has the same type of cells - whatever it is that's being in use in the battery with the IP65 housing.
Anyone know for sure? Thanks!
Membro desconhecido
27 de set. de 2023
The SunSynk IP65 battery uses LifePo4 cells with 51.2V (3.2v x 16 Cells in series = 51.2V nominal voltage). As long as you connect other packs with similar voltage you'll be fine, but the communication can be difficult. One solution is to set it as AGM V or AGM % and set the voltages manually, this works, but you loose some functionality (cant read BMS parameters from the inverter and so on..)
