Exporting battery power to grid
Hi is it possible to use the Sunsynk inverter to force the battery to export to the grid. I would like to export at the peak rate and charge at off peak.
yes you can.
using system mode / timers you can set battery percentages, inverter power (for discharge) and timeslots.
you will also have to enable export.
