Public·391 members
NEUTRAL EARTH BONDING
On an 8kW inverter is it acceptable to connect both neutral and earth to the neutral pole on the load output? I have come across a few installations wired in this way?
I have been installing relays to bond the two when the grid disconnects.
Johnny Sammour
Sep 20, 2022
I can only advise you to get an electrician certified in your area's code. there are many earthing schemes worldwide and only he can identify which one is used where you live, and how to wire your system so its compatible with it.
