Public·486 members
Discharge
My battery is set to only discharge to 80%. Question: Can this be changed to 60% (and is this recommended) Question: If it is recommended (How do i actually make that change on the Inverter) Question: I use the battery and solar panels in combination to Heat my Geyser (water heater), meaning my smart geyser is set, to switch on and off 4-times during the day (peak sunlight hours). Is this repeated change to 100% and discharge to 80% healthy for the batttery. Lastly, in South Africa we often have complete Grid switch-off (National Loadshedding). Question: After sunset, the system drains the battery to 80% avoiding using Grid power. If loadshedding should happen then, how low will the battery drain. Can ths be set? And what is the lowest percentage recommended. I am looking to use the battery as careful as possible to maximise lifespan. Thank You Hano Jacobs
Jun 21, 2023
What type of inverter and batteries are you using?
Are you only relying on the Solar PV to charge the batteries?
