Inverter keeps disconnecting and reconnecting from grid
Only seems to happen when battery is at 100% or when both sets of panels at the front and back of the house are performing well. It'll start with the following notification;
"The system detects that your plant (inverter) disconnected from the grid."
Then a few minutes later I'll get the following notification;
"The system detects that your plant (inverter) power grid has been restored."
Then it just circles round every minute or so
Everything seems to work fine.. its just annoying... have had around 40 of these in the space of an hour this afternoon
Any suggestions? Many thanks in advance.
I have the same problem, disconnect / reconnect. The APP also not working as the Draw from house is Zero? I need local assistance please. South Africa Eastern Cape
