Battery SOC/Discharge
a) can anyone advise what the minimum battery discharge SOC should be - 5%, 10% etc, I have one Sunsynk 5.1 battery.
b) We have currently set our battery to discharge down to 10%, however it will not discharge lower than 30% - why ?????
can anyone help ????
Dont let this bother you.The diff in the two numbers is the watts that the inverter is using to run.Rem your inverter also needs continius power to operate and this is what that diff in the numbers is.
Regards
