Public·395 members
5kW Sunsynk Inverter not switching on after F59 Fault.
Dear Support
I have a new installation with 5kW Sunsynk Inverter 6.35kWp PV and 2x 5.3kW Sunsynk Batteries. It's been setup that the batteries can be used up to 40% and excess PV power can feed back in to the grid. The installation started up the first time without any problems and run for two days when we received the first F56 - DC_VoltLow_Fault. After inspecting the installation with no faults found and measuring all voltages and checking connections, I reset the installation and restarted the system. I then received a F59 - AC_V_GridCurr_High_Fault. The DC and AC LED comes on and you can hear the relay closing inside the inverter but does not want to come on and goes over in to Normal operations. Any suggestions where to start looking or what the problem can be.
mattfjohnson
May 03, 2023
Sorry, meant to reply to this yesterday. I am having an issue where first thing in the morning when the inverter turns on after being in low power mode overnight it would trip the electrics and give an F56 error. I don't know anything about the F59 error.
