Public·392 members
falownik
Dzień dobry,Jestem użytkownikiem  falownika SUNSYNK  SYNK-10K-SG04LP3-EU ,mam w związku z tym kilka pytań:1.czy istnieje instrukcja obsługi w jęz. polskim ?2.czy jest wsparcie techniczne w jęz. polskim?3 jak wygląda kwestia gwarancji i sposobu jej uruchomienia ?4.czy licznik energii typu CHINT DTSU 666 może być alternatywą dla przekładników CT z wyposażenia falownika?5 czy styki 3i 4 złącza CN2 można wykorzystać do połączenia przewodów  N i PE przy pracy wyspowej falownika ? /jest to  złącze bezpotencjałowe  to wiem ,a co z obciążalnością prądową/Krzysztof
Jul 09, 2024
I am sorry - do not read Polish - thanks for the internet I have translated it into English.
Good morning, I am a user of the SUNSYNK SYNK-10K-SG04LP3-EU inverter, I have a few questions: 1. is there a user manual in English? Polish? 2. Is there technical support in Polish? Polish?3 what is the issue of warranty and how to activate it?4.can the CHINT DTSU 666 energy meter be an alternative to the CT transformers included in the inverter equipment?5 can contacts 3 and 4 of the CN2 connector be used to connect N and PE wires during island operation of the inverter? ? /it is a potential-free connector, I know, what about the current carrying capacity/Krzysztof
  1. Unfortunately most manuals and documentation is in English
  2. I can only assume that you have Sunsynk supplier/installer network in Poland
  3. https://www.sunsynk.org/warranty
  4. You can use a CHiNT DTSU666 or EASTRON SDM630MCT meter
  5. Most SS inverters have an ATS output that provides 240V output when the system goes into Islanding mode which is used to operate the neutral bond relay. However it looks like the manual has not identified the ports. I believe that it will be two of the ports in the connector block high lighted in Yellow. This can be verified quite easily using a multimeter while forcing the inverter into islanding mode. I would not use CN2 3/4 for this purpose as I do not think they respond as quickly as the ATS ports/relay do. The ATS port is designed for this function.
