Generator connection
I have 3, 10kw 3phase hybrid inverters connected in parallel to form a 3phase off grid system
With 30kw/h lifpo4 battery system.
My question is, what is the best way to connect my 25kva generator to the system so that the generator can supply power on cloudy days and charge my 30kw/h battery system.
I have been getting conflicting information so thought I would come to this forum.
Further more can I connect the 3phase generator, phase per inverter to the 3 inverters configured as a 3phase system, will I run into synchronization problems? does the generator need to synchronise with the grid or not. It is possible that I will have both Grid and generator supplying the 3 inverters at the same time.
