Solar Panels on 2 'Strings'
I have 5.53Kw of panels (14nr 395W Trina Panels) installed on 2 separate roofs in strings of 10nr panels and 4nr panels respectively. I note on the visual representation on the Sunsynk Connect App that the 2 strings are always comparable readings? My simple thinking is that the 10nr string should mostly always produce 2.5 times the 4nr string (in ideal conditions).
Is the visual representation accurate or purely an aesthetic thing? ie how do I know that all 14nr panels are working correctly?
Hi Chris
Without trying to probe: did you install it? Are you sure that its split 4 and 10 and even though on the roof they are split like that that the installer didn't cable it to be 7 and 7??? That would have made sense to balance the input.......
