Public·324 members
Sunsynk aux for heating
I have the Sunsynk 8Kw inverter, 8K solar array and two sunsynk 5Kw batteries.
The system is set up for primary house use, battery charge, with both satisfied then output to grid ( Octopus Flux ).
What would be the settings on the inverter to use the aux setting to power a 3Kw immersion heater before outputting to the grid?
The system would be solar primary house, charge batteries to 100%, output to aux and when that is satisfied export to grid. When no sun or low light the grid and aux off, the house serviced by remaining solar and battery input?
Many thanks for any pointers. I believe this is the aux display with percentage battery determining output to aux? also the solar output level box?
AVONSIDE
May 02, 2023
yes agree
