Registering parallel inverters
i recently installed and commissoned 2 x 12Kw inverters in parallel with 2 x 10.65kw batteries.
My problem being that the area is quite remote and internet access is not good.
Internet dongles do not hold the the green indication showing that they are connected for long.
How can I rectify this, is there some sort of signal booster available from Sunsynk?
Thanks its a 3G/4G router and is less than a meter away from the inverters. But it requires connection credentials to access the WiFi.
