Public·382 members
Aux port switched off/on for no reason
I am at my wits end. Don't know what the reason for this is. Any help or suggestions are welcome. I have searched the forum for this problem but cant find anything related.
The Aux port is used as an output
The problem:
We get periodic times when connection to all devices on the Aux port is dropped for a few seconds and then come back again after a few seconds.
Conditions:
The battery is full and does not drop below 95%. It actually is 100% when this happens
There is sufficient power from the Solar Panels and Grid power is available.
Settings for Aux port:
Aux Output X
On Grid always on X
Solar Power 5000W
Aux load of Batt 95%
Aux load on bat 100%
Nico Potgieter
May 30, 2023
@DavidSB Thank you for the feedback. I understand how the AUX port works as a smart port. The problem I waa facing was that there is a generator connected to the grid side of the inverter. When the generator is on the AUX port would turn on and off for now reason (so I thought). After a long time found out that the generator freq is not stable and varies a lot causing the Invert to switch on an off.
