Comms cable for Sunsynk 8.8 and B4850 dyness not getting readings on the batteries state with standard cable supplied
do anybody know the pin outs on RJ45 ? also wher to change protocol?
I have used this combination of Sunsynk many times and never had a problem. The cable plug into the Can bus plug on inverter and yhen on the in on the first battery with 3rd dipswitch up. This cable by the way is an standard network patch cable. You must make sure you use the right cable as they supply many cables with batteries. The one is marked Deye.
