Public·386 members
Suggest a Rack for 4 5.12KW Sunsynk batteries
I am trying to get a rack to mount 4 batteries in. I believe a 15U will allow some breathing room. Would I need an 800 deep unit? I suspect I will. Has any one else just used a floor mounted rack... kind of wish I had ordered the rack based inverter too....
Just wondered what solutions that you good people have have used? Obviously 4 wall mounted requires a very large area and the cables wouldn't reach. If i hang them two deep I would need some ridiculously strong brackets. I guess I could use 40x40 alu IR profile or the like, to build my own box, but a prebuilt solution might be best and it needs to hold 200kg.
Any suggestions most welcome. Thanks. Simon
MJ Hospur
2022年11月13日
Have you thought about Unistrut which you build off the floor and fix it to the wall
if you google it there are lots of options
