Public·395 members
Help needed
Perfect sunny day but for the past half hour, I've had very little input. I would expect between 1000/2000. None is going to the grid either. Could there be a problem or am I just not reading it correctly. Battery 100%. In
put 200 only. Output 150. 20 from the grid. Approx figures. Thanks
steve.morris9
steve.morris9
May 20, 2023
Hi that look correct. If it’s easy to see you inverter screen your can try to boil a kettle you should see the screen change instantly. The refreshing rate on the app is around 5 mins so you might not capture the change
