Public·392 members
Fault Codes
I have a sunsynk 5kw inverter with BSL (6.3 kWh) battery bank. Currently the invertor is connected to the electrical grid from the municipality. Coupled to that, the installation contains the data logger and the solarman smart app is used to monitor. Faults codes generated from invertors (verified from UI on the invertor) get sent to solarman app. During times where the municipality stop supplying the power, battery pack supplies power restores power within seconds. Under these conditions where municipality stop supplying the power or electrical failure, i am totally unaware i am running of battery power unless i physically go to inspect the invertor. I wanted to understand, what conditions does F35 No AC grid, generate from the invertor? Currently i am not seeing the error(F35) generate under the invertor's fault code menu, but other fault codes do generate.
