Public·382 members
MULTIPLE SUNSYNK 5kW IN GRID TIE SYSTEM
I am using multiple 5kW Sunsynk inverters in a grid tie system I have been told that a firmware upgrade that will allow paralleling of inverters in a grid tie environment is imminent . Is this true and if so when can we expect it ?
any.day.renew
any.day.renew
Sep 13, 2023
You should check the firmware versions of all inverters. They need to be all the same version to enable paralleling. To get them all upgraded to the latest version you need to request from Sunsynk support. The firmware is not updated without a request from yourself.
I support two properties, each with a pair of 5kW inverters, both are updated to enable parallel running and work fine.
