DNO for 5.5kW system
Hi everyone, wow what a piece of kit, got the 5.5 model then was told I would need to go through DNO in the UK!! Filling out the DNO form I need to know what IDC and RC; PGM Registered Capacity (kW)* I am thinking this is the 5.5kW but not sure.
Has anyone completed their own DNO for the UK as I am using form Form A1.2 Application for connection of Fully Type Tested Generation under the Small Generation Installation Procedures, as the unit will produce less than the max 32 amps back to the grid.
Need help asap as want to get it all legal lol
I am currently waiting for [final] approval from DNO. I have form A3-2 Part 1 and Appendix C (CLS) for an 8kW inverter with a 5kW MEL. This is what the DNO wanted.
I am not sure how far you are along this process but at some point the DNO inspector will be in touch so, I assume, YOUR DNO INSPECTOR will say what forms he wants!
